Already a member?
Sign in
Discussion: Quiet speakerphone
Keyword tags:
Earpiece volume
Speaker volume
Watch
jreimche jreimche |
Quiet speakerphone
Jul 10 2007, 7:36 PM EDT Something went wrong with my Q and now the speaker's are nearly inaudible when playing music or movies. The speakerphone works great however and my phone rings loud enough for me to hear across the house. With the limited adjustments in the software, I can't find a way to turn up the volume on the Media player (I've tried the thumbwheel and Media Volume settings to no avail). Has anyone else run into this problem, and/or knows how to fix it??? 6 out of 7 found this valuable. Do you? |
Editman54 Editman54 |
RE: Quiet speakerphone
Aug 1 2007, 12:50 AM EDT Yes, exact same problem. At one point my Q seemed to reset itself and my speakers worked fine for awhile. All of a sudden the problem resurfaced. If anybody here as a solution for this please post! Thanks! p.s. For a while I thought this could have something do to with conflicting bluetooth settings/hardware. Any thoughts on this? 2 out of 2 found this valuable. Do you? |
gpon425 gpon425 |
Feb 12 2008, 11:30 PM EST Misery loves company. I'm having the same troubles. I also think it has something to do with bluetooth which I turn on & off frequently. I am still trying to find a workaround. 0 out of 1 found this valuable. Do you? |
nanvaughn nanvaughn |
Feb 23 2008, 3:16 PM EST Same problem with my MotoQ. I use bluetooth occasionally, BUT this problem started way before then. I also have audio problems when I have tried to use to voice recorder. Have no idea how to get the sound to increase. Hope some one does. Do you find this valuable? |
gpon425 gpon425 |
Mar 22 2008, 11:43 AM EDT I got it!!!! This is what I did. Press & hold the jog wheel until EARPIECE VOLUME shows up then roll the jog wheel WHILE STILL PRESSING IT IN! My earpiece volume was set pretty low. Now we will see if it stays that way. 9 out of 9 found this valuable. Do you? |
