Discussion: Skin Case
Keyword tags: None
Watch
Anonymous  (Get credit for your thread)
edl
edl
Skin Case
Sep 6 2006, 12:26 PM EDT
Love the skin cases. The tight fit keeps the Q dimensions very well. The rubber holds the shape. The cutouts fit perfectly and the rubber gives it enough tackiness to keep it firm in the hand and it can't get knocked off a table. Also, cleaning is easy. Just take off the skin and wash it under warm soapy water.One problem, I bought the Motorola charger cradle and the Q doesn't fit in the cradle with the skin on. 5  out of 6 found this valuable. Do you?
Anonymous
RE: Skin Case
Sep 9 2006, 3:39 PM EDT
"Love the skin cases. The tight fit keeps the Q dimensions very well. The rubber holds the shape. The cutouts fit perfectly and the rubber gives it enough tackiness to keep it firm in the hand and it can't get knocked off a table. Also, cleaning is easy. Just take off the skin and wash it under warm soapy water.One problem, I bought the Motorola charger cradle and the Q doesn't fit in the cradle with the skin on. "
Does anybody know if the skin cases come with a belt clip?
1  out of 1 found this valuable. Do you?
