Already a member?
Sign in
Discussion: Double Contact Entries: Hard ReSET?
Keyword tags:
faq
motorola+q
Watch
leaddoris leaddoris |
Apr 6 2008, 5:55 PM EDT Q/Verizon: I don't use the wireless sync by Verizon; I use intellisync. All my contacts are in my phone twice - is there a way to delete one set without doing a hard reset? If I do a hard reset, will I have to download the software again for my intellisync function? And, what else will I lose when It resets. ALSO: When calling an auto attendant VM and trying to enter letters of a name from the numeric keypad, is there a way to get the Q to go to phone function with the numbers? so you can look up someone in a company directory? 1 out of 2 found this valuable. Do you? |
demon380 demon380 |
RE: Double Contact Entries: Hard ReSET?
Jul 21 2008, 10:41 AM EDT For the double contact entries, I'd recommend downloading Yahoo Go version 2.0 . But you must download version 2.0 because 3.0 doesn't have the phonebook autosync. You would need a yahoo mail account also(free). Once you've installed the program, in the options, there should be a feature called address book sync, run that. Once it's done, on a computer log into your yahoo account, and click Contacts, you should see what your phonebook had, in doubles. Now click Options, and there should be an option called "Clean Up Duplicates". Run that, once it's done and everything on the yahoo side is good, run the Yahoo Go program on the Q again and sync the address book again. Once it's done, your Q's contact's shouldn't be in doubles anymore. Hope that helps! 0 out of 1 found this valuable. Do you? |
Excalibrate Excalibrate |
Aug 11 2008, 3:06 AM EDT You would probably be better off with the Windows Mobile Device Center to sync with Outlook (2003 or 2007). There are many tools available for removing dupes, especially if running Outlook to manage your contacts. Check this page for some options. http://www.slipstick.com/addins/contacts_dups.asp Hope this helps. Excalibrate Sprint ATS - El Paso Do you find this valuable? |
